[gdal-dev] Adding an alpha channel to a Virtual Dataset then Writing it out to a TIFF in C#
avtoader avtoader at gmail.com
Thu May 31 18:05:57 PDT 2012
I fixed the issue by using the "MEM" driver instead of the "VRT".  It was
really helpful and sped up my image output by a lot!
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-dev-Adding-an-alpha-channel-to-a-Virtual-Dataset-then-Writing-it-out-to-a-TIFF-in-C-tp4977895p4978428.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
