[gdal-dev] Ogr and Dwg via Teigha (in C#)
Noon Silk noonslists+gdal at gmail.com
Thu Nov 1 15:30:16 PDT 2012
On Mon, Oct 29, 2012 at 11:34 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
> You might also take a look at the -dev packages at
> http://www.gisinternals.com/sdk/
> The compilation is controlled by a single makefile, so you can use:
> nmake gdal
> nmake gdal-csharp
Thanks; I happened to grab the "MSVC2005 (Win64) -development", which
doesn't have that ..., I'll give this a go.
> to achieve the desired result.
> Best regards,
> Tamas
Noon
