[gdal-dev] Selecting Python during configuration
Michael Speth SpethM at landcareresearch.co.nz
Thu Nov 1 18:01:26 PDT 2012
Greetings,
  I am attempting to compile gdal with python support.  However, I don't want to use the system installed python; I want to use a locally compiled version of python.  I am unable to find how to select the python version to use with the gdal install.
It seems that --with-python doesn't have an option to set the python install directory; --with-hdf5 can set the install directory of hdf5.
Is there a way to set gdal to point to a different install directory for python?
If not, how does gdal find the path to python?  Is it possible to set an environment variable (I am compiling on GNU/Linux)?
Thanks
Michael Speth
Research Systems Developer
Landcare Research
Please consider the environment before printing this email
Warning: This electronic message together with any attachments is confidential. If you receive it in error: (i) you must not read, use, disclose, copy or retain it; (ii) please contact the sender immediately by reply email and then delete the emails.
The views expressed in this email may not be those of Landcare Research New Zealand Limited. http://www.landcareresearch.co.nz
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121102/38ee5eb2/attachment.html>
