[gdal-dev] Problem with GUID-field in FileGDB driver
Even Rouault even.rouault at mines-paris.org
Fri Nov 2 09:42:05 PDT 2012
Selon Simon Lyngby Kokkendorff <silyko at gmail.com>:
> Hi List,
>   I have been trying to transform some FileGDB databases with OGR and have
> run into a problem reading a specific field called "GlobalID". The field
> simply cannot be read by OGR, which emits this warning (and the field is
> left as NULL):
Simon,
could you file a ticket in GDAL Trac and attach such a FileGDB in it ? It
shouldn't be hard to fix.
Even
