[gdal-dev] ogr I/O language problem patch.
Sun Nov 4 20:29:24 PST 2012
On 12-11-04 05:12 PM, OKI Miyuki wrote:
> Hi, all.
>    I made patch for GDAL/ogr command line program
> on windows platform.
> https://www.box.com/s/tqvek2gso065iq7lmo3c
> ogr_lang.diff   is patch for version 'gdal-2.0dev.'
> https://svn.osgeo.org/gdal/trunk/gdal
> This patch concept is 'using CP_ACP' for command line program.
> CP_ACP description was here.
> http://msdn.microsoft.com/en-us/library/windows/desktop/dd374130(v=vs.85).aspx
> First time, on windows platform, it's fine to
> run batch file with UTF-8. But argument charcter code
> chagned through. To understand this problem,
> see follow test code.
> https://www.box.com/s/zi6ugdjcjrwf7h4ycj7c
Miyuki,
The patch looks promising.  Could you file it as a GDAL ticket at:
   http://trac.osgeo.org/gdal/
Best regards,
light and sound - activate the windows | http://home.gdal.org/warmerda
and watch the world go round - Rush    | Geospatial Software Developer
