[gdal-dev] Is there any way of accesing the GDAL utilities from C#?
Dev3 devdatta at tengshe.in
Tue Nov 6 20:45:03 PST 2012
Hi All!
I am trying to do some data processing in my .NET application. I have found
that my work is done by using just two of the gdal utilities: gdal_rasterize
& gdal_fillnodata.
However, when I downloaded the C# bindings, I realized that the utilities
are not part of it. Is there any quick way of getting the utilities from C#,
or will it be quicker to just use System.Diagnostics.Process.Start() method,
to run the gdal Utilities on the command line?
View this message in context: http://osgeo-org.1560.n6.nabble.com/Is-there-any-way-of-accesing-the-GDAL-utilities-from-C-tp5014441.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
