[gdal-dev] Is there any way of accesing the GDAL utilities from C#?
Etienne Tourigny etourigny.dev at gmail.com
Tue Nov 6 23:38:44 PST 2012
Hi
for now you can use them as command-line apps only, although Even did
mention he wanted to make them available as (python) bindings - this
might make it in 2.0
cheers
Etienne
On Wed, Nov 7, 2012 at 2:45 AM, Dev3 <devdatta at tengshe.in> wrote:
> Hi All!
> I am trying to do some data processing in my .NET application. I have found
> that my work is done by using just two of the gdal utilities: gdal_rasterize
> & gdal_fillnodata.
> However, when I downloaded the C# bindings, I realized that the utilities
> are not part of it. Is there any quick way of getting the utilities from C#,
> or will it be quicker to just use System.Diagnostics.Process.Start() method,
> to run the gdal Utilities on the command line?
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Is-there-any-way-of-accesing-the-GDAL-utilities-from-C-tp5014441.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
