[gdal-dev] [Osgeo4w-trac] random crashes upon using ogrinfo or ogr2ogr with FileGDB
Wed Nov 7 17:45:00 PST 2012
On 12-11-07 05:13 PM, Martin Feuchtwanger wrote:
> Jeff McKenna suggested (privately) that i try MS4W. He didn't really say why, and i suspected it wouldn't work because both OSGeo4W and MS4W seem to use the same version of the FileGDB driver (at least, both FileGDBAPI.dll files are identical).
> However, MS4W is still using GDAL 1.9.1 (2012/05/15) while OSGeo4W is now using GDAL 1.9.2 (2012-10-08), and, running the same ogrinfo and ogr2ogr tests (via OSGeo4W) on GDB files, there are no more crash problems!
> Thus, there seems to be a problem with GDAL in the change from 1.9.1 (2012/05/15) to 1.9.2 (2012-10-08), when using FileGDB.
> I'm very new here -- should i be reporting this elsewhere?
> Martin Feuchtwangerfeumar at shaw.ca   604-254-0361
Martin,
Ah, I suspect this is the same problem as using other OSGeo4W
GDAL plugins with the new version of GDAL built with a different
version of visual studio.
With OSGeo4W you can switch back to the 1.9.1 GDAL version and things
should work.  Hopefully the FileGDB plugin will be rebuilt soon.
Best regards,
light and sound - activate the windows | http://home.gdal.org/warmerda
and watch the world go round - Rush    | Geospatial Software Developer
