[gdal-dev] gdalinfo on PostGIS rasters (GDAL 1.9)
Even Rouault even.rouault at mines-paris.org
Thu Nov 8 10:52:40 PST 2012
> Even, that's what I was afraid of... I think I will give it a try. Is there
> a preferred solution between sources from Subversion and the nightly
> snapshots?
up to you
> Second, do I understand it correctly that I need to 1) install GDAL from
> sources,
yes
> and 2) recompile PostGIS on this GDAL version?
not necessarily. The raster module of PostGIS doesn't use the GDAL
PostGISRaster driver (AFAIK)
> Third, can GDAL trunk live together with my current version of GDAL?
Yes, you have to ./configure --prefix=/some/path and then by adjusting the PATH
and LD_LIBRARY_PATH environmenet variables, you can run your custom build of
GDAL.
