[gdal-dev] Suggestion for API addition
Even Rouault even.rouault at mines-paris.org
Sun Nov 11 02:53:14 PST 2012
Le dimanche 11 novembre 2012 03:45:57, David Strip a écrit :
>  The current GDALRasterBand::RasterIO signature makes it easy to read or
> write a contiguous subregion of the band. However, if you want to read or
> write the entire band into/from  a contiguous sub-region of the buffer,
> it's not nearly as straightforward. You can do this by using the
> nLineSpace parameter, giving the size of the subregion for buffer size
> parameters,  and offsetting the address of the buffer. It works, but that
> makes the code a bit baroque and hard to read.
>  How about a signature that indicates the entire band will be read, but
> moves the meaning of the offset to the buffer. Something like
> CPLErr GDALRasterBand::RasterIO   ( GDALRWFlag eRWFlag,
>                                    int   nXSize,
>                                    int   nYSize,
>                                    void * pData,
>                                    int   nBufXOff,
>                                    int   nBufYOff,
>                                    int   nBufXSize,
>                                    int   nBufYSize,
>                                    GDALDataType    eBufType,
>                                    int   nPixelSpace,
>                                    int   nLineSpace   )
>    Obviously I can write a wrapper for this functionality that just calls
> RasterIO, setting the appropriate values for buffer size, etc, but I was
> thinking I might not be the only one who wants to crop a buffer while
> writing to the band, or reading a band into a sub-region of a buffer.
This is just a personal opinion, but I'm not convinced this is a good idea. I
think people will be more confused than currently. The meaning of the
parameters of the existing RasterIO() requires some time to be confortable
with, but once you've finished learning curve, it is pretty logical. Adding
another method with the same name, almost same parameters, but subtle
differences in behaviour is not going to make users life easier.
Why not adding an example code snippet of your use case in the documentation
of the current API ? (if I've understood well, your proposal is just a
convenient way of computing the right value for pData, likely pData =
pBufferBase + nBufYOff * nLineSpace + nBufXOff * nPixelSpace)
Furthermore, if you want to operate on the whole band, you should also remove
the nXSize and nYSize parameters that are useless.
>  This cropping interpretation doesn't allow for decimation/replication. It
> requires the buffer size be large enough to copy the entire band into the
> sub-region of the buffer. Allowing for decimation/replication would
> require yet more parameters.
Not sure to understand that. The presence of nBufXSize, nBufYsize in your
proposal allows subsampling/oversampling. Perhaps you meant something else
with decimation/replication ?
