[gdal-dev] No Spatial Reference System from UTM Ozi .map file
Jean-Claude Repetto jrepetto at free.fr
Mon Nov 12 00:02:52 PST 2012
On 12/11/2012 08:16, Nik Sands wrote:
> Is that limitation actually built into GDAL?
> Because 2-point .map files are not uncommon, and so long as the two points are both different in both axes, then there should be no reason why a 3rd point in required (especially in UTM).
> Nik.
Have you checked if adding a third point solves your problem ?
Jean-Claude
