[gdal-dev] Hide OGR_STYLE from PDF attributes
Even Rouault even.rouault at mines-paris.org
Mon Nov 12 13:24:20 PST 2012
Le lundi 12 novembre 2012 15:57:09, Jukka Rahkonen a écrit :
> Jukka Rahkonen <jukka.rahkonen <at> mmmtike.fi> writes:
> > I wonder also why the the example about using png images as symbols in
> > the document http://www.gdal.org/ogr/drv_pdf.html includes  settings for
> > the symbol color. OGR_STYLE in the example is
> > SYMBOL(c:#000000,id:"a_symbol.png"). Does some of the supported image
> > formats really support changing colors on-the-fly?
> I can tell now that color can be used for adjusting transparency if alpha
> channel is included too. The example it not the best possible because
> SYMBOL(c:#000000,id:"a_symbol.png") means the same as plain
> SYMBOL(id:"a_symbol.png") and resulting symbol will be 50% opaque.
Actually SYMBOL(c:#000000,id:"a_symbol.png") would result in a opaque symbol,
whereas SYMBOL(id:"a_symbol.png") would use the default alpha for brush,
that's to say 50%.
> Perhaps the example could be edited a bit:
> Alpha channel value controls the opacity/transparency
> SYMBOL(c:#000000FF,id:"a_symbol.png") makes 100% opaque symbol
I've tried to improve the doc about that in r25219.
> -Jukka-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
