[gdal-dev] No Spatial Reference System from UTM Ozi .map file
Nik Sands nixanz at nixanz.com
Mon Nov 12 16:03:38 PST 2012
Thanks for the replies so far.  Unfortunately, adding a 3rd calibration point to the .map file has not helped.  Of course I'm assuming that the added calibration point is valid (eg, I tried the one suggested below, which looks like it should be OK).
Does anybody have any other suggestions as to why this .map file cannot be interpreted correctly by GDAL?
Is it a bug, or an incomplete .map parsing implementation, or am I doing something wrong?
Cheers,
Nik.
On 12/11/2012, at 11:38 PM, Jukka Rahkonen <jukka.rahkonen at mmmtike.fi> wrote:
> Nik Sands <nixanz <at> nixanz.com> writes:
>> I appreciate that (hence pasting the content of the file in my original
> email).  However, I don't know how to
>> be certain that the text I put into the file represents something that makes
> sense.
>> However, as I said I will give it a shot (when I get back to my computer).
> This is my guess:
> Point01,xy,    0,    0,in, deg,    ,        ,,    ,        ,, grid,
> 55,219999.09067205,5570000.7412442,S
> Point02,xy, 1000, 1000,in, deg,    ,        ,,    ,        ,, grid,
> 55,223259.16350298,5566740.6684133,S
> Point03,xy,    0, 1000,in, deg,    ,        ,,    ,        ,, grid,
> 55,219999.09067205,5566740.6684133,S
> Having two calibration points in OziExplorer .map files is not at all uncommon
> and with digital maps and orthophotos in some projected coordinate system there
> is no need to have more. Same situation basically than with ESRI world file
> georeferencing when just one anchor point and pixel size is given.
> http://www.oziexplorer3.com/eng/features/features_moreinfo3.html
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
