[gdal-dev] SQLite Driver and non-spatial tables
Kyle Shannon kyle at pobox.com
Tue Nov 13 12:44:53 PST 2012
I have a Spatialite enabled SQLite file with both spatial and non-spatial
tables.  Since my database has a table called geometry_columns, all
non-spatial tables are not loaded as layers.  If I don't have a
geometry_columns OGR attempts to load geometry from all the tables, but
still loads non-spatial tables.  Is that correct?  The behavior doesn't
seem consistent in the two cases.  I just want to make sure I understand
the driver's behavior.
kss
