[gdal-dev] ImportError when importing gdal module with python 2.7 on Windows 7 64-bit
Joaquim Luis jluis at ualg.pt
Thu Nov 15 10:21:33 PST 2012
I am also (moderately) interested in this.
 From what I remember, Even once explained us that the problem is that
official Python binaries are built with VS2008 (or 9) and the GDAL from
Tamas is from VS2010 and so the dlls are incompatible. However, I did a
home built of Python with VS2010 and still got problems of this kind
(not sure of the details anymore).
Joaquim
> I usually struggle with the same problems over and over again. Try using Dependency Walker (http://www.dependencywalker.com/) to see if you are missing a library or two. I used it to determine that I was missing these two files:
>      msvcp100.dll
>      msvcr100.dll
> I remember something about Microsoft removing these during some updates. They might be needed in your path.
> I don't know if that helps :)
> Regards, Casper
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of nnneogeorge
> Sent: 15. november 2012 18:59
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] ImportError when importing gdal module with python 2.7 on Windows 7 64-bit
> Hey guys,
> I am using the python 2.7.3 64b, with the GDAL 64b (tried both 19&  20
> versions) under windows 7 64b, I have followed all the steps here
> http://www.gis.usu.edu/~chrisg/python/2009/docs/gdal_win.pdf
> and here
> http://pythongisandstuff.wordpress.com/2011/07/07/installing-gdal-and-ogr-for-python-on-windows/
> took the software from here
> http://www.lfd.uci.edu/~gohlke/pythonlibs/
> http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1400-x64-gdal-mapserver.zip
> And experimented with all the possible folder paths, added in the Environmental Variable... the modules osGEo and gdal are both in the list of python (I can check through>  help ("modules") , but when I ask for more information on these, it throws the following error
> problem in osgeo -<type 'exceptions.ImportError'>: DLL load failed: The specified module could not be found.
> ofcourse the same goes when I try to import gdal ,I m getting the following
> message:
> Traceback (most recent call last):
> File "<pyshell#0>", line 1, in<module>
> import gdal
> File "C:\Python27\lib\gdal.py", line 2, in<module>  from osgeo.gdal import deprecation_warn File "C:\Python27\lib\osgeo\__init__.py", line 21, in<module>  _gdal = swig_import_helper() File "C:\Python27\lib\osgeo\__init__.py", line 17, in swig_import_helper _mod = imp.load_module('_gdal', fp, pathname, description)
> ImportError: DLL load failed: The specified module could not be found.
> Which I guess should understand that the dll that supposed to be created, well hasnt...
> Checked manually and yeap its true, couldnt find it -
> Then I tried to check if the path was right for sure, so opening the windows console and typing "set" gave me the list with the path variables -->  all right.
> Also the osgeo command-line works perfectly fine.
> Any ideas or things to try more than welcome...
> Thanks a lot,
> George.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-dev-ImportError-when-importing-gdal-module-with-python-2-7-on-Windows-7-64-bit-tp5006198p5016723.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
