[gdal-dev] gdal 1.9 path problem when I using special characters
netcadturgay turgay.osna at netcad.com.tr
Mon Nov 19 04:55:29 PST 2012
I can not read the ECW files if filename contains special characters(ş,İ,ğ
etc.). I use gdal 1.9 library including ERDAS ECW Read-Write SDK. Also I
tried to set GDAL_FILENAME_IS_UTF8=NO but it does not work.
Can you help me about this problem?
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-1-9-path-problem-when-I-using-special-characters-tp5017353.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
