[gdal-dev] GDALINFO cannot pipe to text file
fred.dss fred.dss at free.fr
Wed Nov 21 21:05:29 PST 2012
Same problem for me. I try to use gdalinfo.exe to read metadata from .tif
images. Here's an example for shell command :
C:\gdalinfo.exe test.tif>test.txt
Everything works very well on windows xp pro 32 bits but with on windows
seven 64 bits, the result file text.txt is empty.
What's solution ?
Thanks
View this message in context: http://osgeo-org.1560.n6.nabble.com/GDALINFO-cannot-pipe-to-text-file-tp3747928p5018053.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
