[gdal-dev] CRS not defined with BMP
Clay, Bruce bclay at ball.com
Mon Nov 26 05:23:47 PST 2012
I am using GDAL to convert CADRG files to BMP chips for an application written to only use BMP.  I have created the BMP chip, BMP world file and a 4326 prj file to indicate WGS 84.  When I use gdalinfo to look at the settings it always indicates  CRS is not defined.  QGis also says the CRS is not defined.  Is there a proper way to define a CRS for rasters that rely on a world file?
Bruce
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121126/b76a2d48/attachment-0001.html>
