[gdal-dev] OpenJPEG 2.0 released
Angelos Tzotsos gcpp.kalxas at gmail.com
Mon Nov 26 10:46:14 PST 2012
On 11/26/2012 05:44 PM, Even Rouault wrote:
> Selon Jeff McKenna <jmckenna at gatewaygeomatics.com>:
>> On 12-11-26 5:51 AM, Angelos Tzotsos wrote:
>>> Thanks Even,
>>> I have disabled openjpeg2 support until 1.10.
>>> Cheers,
>>> Angelos
>> Thanks Angelos/Even, I will do the same.
> Just to be clear: if you have already packaged GDAL 1.9 with openjpeg "old" v2
> branch, there's no reason to change that right now, unless you have other users
> of openjpeg 2.0 or have some other good reason to upgrade it now.
The issue in my case is that openjpeg was updated upstream in openSUSE
Factory so the previous gdal package does not find the correct SO name,
so it breaks.
>> -jeff
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> http://www.gatewaygeomatics.com/
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best,
Angelos
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
