[gdal-dev] Space in PDF option OGR_DISPLAY_LAYER_NAMES
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue Nov 27 00:28:06 PST 2012
Even Rouault <even.rouault <at> mines-paris.org> writes:
> There was indeed something wrong in the way the layer name was written for the
> model tree, which caused invalid PDF structure to be generated when there were
> spaces (and potentially non-alphanumeric characters) in the layer name. This
> should be fixed by r25257
Seems to work mostly. However, Adobe Reader X version 10.1.4 shows an error
message when I open my test map. As translated it is roughly
"Font Times_Roman contains a faulty /Bbox tag"
Perhaps because of this my bus stop layer which has both symbols and labels does
not show attributes in the model tree when the labels are visible. When I turn
the labels off the model tree show the attributes again.
-Jukka-
