[gdal-dev] Absolutely no progress trying to compile GDAL with Oracle support on Windows
Nicolas Simon nicolas.simon at spw.wallonie.be
Tue Nov 27 05:46:36 PST 2012
Hello,
  Could should try gdalinfo --formats   ?
  It will shows you if OCI driver was correctly included in the build.
  If it's not the case, may be you should force a new rebuild with these commands
    nmake -f makefile.vc clean
    nmake -f makefile.vc install
  If you have OCI driver in the list, the problem probably comes from your datasource definition (the string starting with OCI: )
  Nicolas
-----Message d'origine-----
De : gdal-dev-bounces at lists.osgeo.org
[mailto:gdal-dev-bounces at lists.osgeo.org]De la part de cheesybiscuits
Envoyé : mardi 27 novembre 2012 3:01
À : gdal-dev at lists.osgeo.org
Objet : [gdal-dev] Absolutely no progress trying to compile GDAL with
I've started a couple of threads on this forum recently trying to figure out
similar problems and currently compiling GDAL 1.9.2 from source on Windows
looks like my best option - but STILL I'm getting nowhere. I can't believe
how much time this is taking!
I've set up my nmake.opt file with everything it needs for OCI:
# Add ORACLE support.
# Uncomment the following line to enable OCI Oracle Spatial support.
ORACLE_HOME =	C:\app\mirawan\product\11.2.0
# Uncomment the following if you prefer to build OCI support as a plugin.
# OCI_PLUGIN = YES
!IFDEF ORACLE_HOME
OCI_LIB =	$(ORACLE_HOME)\client_1\sdk\lib\msvc\oci.lib
OCI_INCLUDE =	-I$(ORACLE_HOME)\client_1\sdk\include
!ENDIF
I've verified several times that the relevant files are where I think they
are.
I can compile and install with nmake /f makefile.vc and nmake /f makefile.vc
install with no trouble. No error messages related to OCI are reported in
the build output, even in debug mode (nmake /f makefile.vc DEBUG=1). However
when I try to open an OCI data source I just see 'Unable to open datasource
... with the following drivers'.
I also tried adding OCI support as a plugin but this was even more
frustrating - I followed the steps  here
<http://trac.osgeo.org/gdal/wiki/BuildingOnWindows>   to compile plugins and
nmake ran without any error but apparently nothing changed. TBH I don't even
know if I'm looking at the correct plugin  - I assume I want georaster for
all Oracle support but I can't find any useful documentation on the
relationship between georaster and OCI.
I am pretty much at the point of putting through my screen in anger. Can
anyone give me any idea what's going on here, or a better way of figuring
out what the problem might be?
Even better - can anyone suggest an automated way of exporting Oracle data
to File GeoDatabase that doesn't involve GDAL or FME?
Thanks
View this message in context: http://osgeo-org.1560.n6.nabble.com/Absolutely-no-progress-trying-to-compile-GDAL-with-Oracle-support-on-Windows-tp5018926.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
