[gdal-dev] Space in PDF option OGR_DISPLAY_LAYER_NAMES
Even Rouault even.rouault at mines-paris.org
Tue Nov 27 13:40:06 PST 2012
Le mardi 27 novembre 2012 09:28:06, Jukka Rahkonen a écrit :
> Even Rouault <even.rouault <at> mines-paris.org> writes:
> > There was indeed something wrong in the way the layer name was written
> > for the model tree, which caused invalid PDF structure to be generated
> > when there were spaces (and potentially non-alphanumeric characters) in
> > the layer name. This should be fixed by r25257
> Seems to work mostly. However, Adobe Reader X version 10.1.4 shows an error
> message when I open my test map. As translated it is roughly
> "Font Times_Roman contains a faulty /Bbox tag"
> Perhaps because of this my bus stop layer which has both symbols and labels
> does not show attributes in the model tree when the labels are visible.
> When I turn the labels off the model tree show the attributes again.
Ah it took me some time to realize that you meant that the error was new after
the r25257 commit... ok, this is now fixed by r25261
> -Jukka-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
