[gdal-dev] Absolutely no progress trying to compile GDAL with Oracle support on Windows
Tamas Szekeres szekerest at gmail.com
Wed Nov 28 00:37:30 PST 2012
GDAL plugins should either be installed into a /gdalplugins subdirectory
from where the executable is running or set GDAL_DRIVER_PATH to point to
the directory containing these files. With regards to
gisinternals<http://www.gisinternals.com/sdk/>both the oracle and the
filegdb plugins are provided, however you must copy
them to the desired locations manually. You should also download and
provide binaries of the proper version of the OCI (ie. instantclient) and
the FileGDB libraries being available in the PATH, which cannot be
distributed from gisinternals <http://www.gisinternals.com/sdk/> due to
licensing restrictions.
Best regards,
Tamas
2012/11/28 cheesybiscuits <thomaschristian at gmail.com>
> Eli - thanks a bunch for mentioning the .bat file - that got Oracle support
> working!
> I really should have seen that, and the read-me in the same directory
> telling me to run it... I've just got into a routine of getting the
> binaries, testing with the same commands, and being disappointed.
> This may be better placed as a separate question, but hopefully it's an
> easy
> / quick answer:
> Whilst Oracle support is working FileGDB is not. gisinternals.com claims
> ogrinfo --formats includes FileGDB support but I don't seem to have it. I
> have the FGDB API (version 10.0?) installed and its binaries are included
> in
> the path, but for some reason this driver isn't available.
> Any hints on this last problem would be great. My backup plan is exporting
> to Shp but I have some field names longer than 10 characters and I don't
> want to dive into that mess
> http://osgeo-org.1560.n6.nabble.com/Absolutely-no-progress-trying-to-compile-GDAL-with-Oracle-support-on-Windows-tp5018926p5019199.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121128/ae215aaa/attachment.html>
