[gdal-dev] 64bit integers
Jeremy Palmer JPalmer at linz.govt.nz
Wed Nov 28 13:26:51 PST 2012
I have a WFS layer with a 64bit integer field (sufi):
http://wfs.data.linz.govt.nz/83de09e2215a4d0c914dbfe28bb71557/v/x1208/wfs?service=WFS
When using ogr this 64bit integer field gets truncated to 32bit without any warning. E.g
ogrinfo -al 'wfs:http://wfs.data.linz.govt.nz/83de09e2215a4d0c914dbfe28bb71557/v/x1208/wfs?service=WFS&MAXFEATURES=1'
OGRFeature(v:x1208):1384201
  gml_id (String) = x1208.1384201
  id (Integer) = 1384201
  sufi (Integer) = -1519442684
  name (String) = Copy of Daffodil Bay Road
  locality (String) = Sandy Point
  created (String) = 2012-09-04T01:04:02Z
  modified (String) = 2012-09-04T01:04:02Z
  text (String) = (null)
  unofficial_flag (String) = O
  editor (String) = jbedford
  version (Integer) = 1
  edit_action (String) = N
  status (String) = H
This of course then flows through to all drivers such as sqlite, postgresql, mysql, mssql etc.
Should ogr not cast these 64bit integers to an ogr string so data is not lost? At least until http://trac.osgeo.org/gdal/wiki/rfc31_ogr_64 is implemented?
Thanks,
Jeremy
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
