[gdal-dev] Creating new column with filename, scripting shapefiles
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Nov 29 09:54:49 PST 2012
Joe,
What was the full warning message about the normalized/laundered field
name? Field name is modified when the name is longer than 10 characters or
when a field with same name exists.
Check the name of the newly created field.
As per the update command, I don't think the update command is implemented
in the ogr sql yet. You can do it in the sqlite format, among other rdbms
formats. Use ogr2ogr to convert it to sqlite. update it. convert it back to
shapefile.
On Thu, Nov 29, 2012 at 8:58 PM, Joe Larson <joe at joelarson.com> wrote:
> I have tried these three methods to add a filename column while scripting
> a folder of shapefiles, with a Bash script - which results in `Warning 6:
> Normalized/laundered field name` & `ERROR 1: SQL Expression Parsing Error:
> syntax error` messages and NULL values in the created column :
> #1
> for f in *.shp;
> do
> name=${f%.shp}
> ogrinfo $f -sql "ALTER TABLE $name ADD COLUMN filename character(10)"
> ogrinfo $f -sql "UPDATE TABLE $name filename = '$f'"
> done;
> #2
> for f in *.shp;
> do
> name=`echo "$f"|sed 's/\.shp$//g'`
> done;
> #3
> for f in *.shp;
> do
> name=`basename $f .shp`
> done;
> There's an example here http://trac.osgeo.org/gdal/wiki/FAQVector called
> "How do I include the source filename in a field when merging hundreds of
> shapefiles (Windows)?" I also cannot get this to work - getting
> "unrecognized fieldname" message.
> Perhaps my variable does not work in the Bash SQL statement. I'm not sure
> what's going on in the Windows example.
> Regards,
> Joe Larson
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121129/54ee7923/attachment.html>
