[gdal-dev] Forces SRS into VRT ? (gdalbuildvrt)
Oyvind Idland oyvind.idland at gmail.com
Tue Oct 2 00:05:47 PDT 2012
Hi Even,
thanks ! :)
- Oyvind
On Mon, Oct 1, 2012 at 11:26 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Le lundi 01 octobre 2012 16:07:15, Oyvind Idland a écrit :
> > Hello,
> > is it possible to force an SRS into a .vrt in some way, during creation ?
> > (except manually copying into the .vrt)
> > In my case, I got a tiled dataset in .jpeg, with no SRS information
> > attached. Since I know the projection,
> > I am looking for an "-a_srs" or similar.
> I've just added the -a_srs option in the trunk version of gdalbuildvrt.
> Otherwise you can already download the following GDAL Python script :
> http://svn.osgeo.org/gdal/trunk/gdal/swig/python/samples/gdal_edit.py
> and then for example try :
> python gdal_edit.py -a_srs EPSG:32660 foo.vrt
> gdal_edit can update in place various metadata (depending on the
> capabilities
> of the underlying format) :
> $ python gdal_edit.py
> Usage: gdal_edit [--help-general] [-a_srs srs_def] [-a_ullr ulx uly lrx
> lry]
>                  [-tr xres yres] [-unsetgt] [-a_nodata value]
>                  [-gcp pixel line easting northing [elevation]]*
>                  [-mo "META-TAG=VALUE"]*  datasetname
> Edit in place various information of an existing GDAL dataset.
> > - Oyvind
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121002/11c3d900/attachment-0001.html>
