[gdal-dev] gdal-dev Digest, Vol 101, Issue 3
Pravin Ramteke ramteke0001 at gmail.com
Wed Oct 3 01:44:12 PDT 2012
Respected Sir,
Thank you for your reply,
As u said i have configured using gdal --with-rename-internal-
libtiff-symbols and --with-rename-internal-libgeotiff-symbols
When operating on .tif image i get same  error again
*** glibc detected *** ./Multispectral: malloc(): memory corruption:
0x09edecf0 ***
I am using gdal 1.9.1 version strictly i need to have gdal 1.9.0
can u please suggest me a solution..............
Thank You,
Regards
Pravin B. Ramteke
MTech-II (CSE)
Walchand College Of Engg,
Sangli,
Maharashtra. 416415
On Wed, Oct 3, 2012 at 12:30 AM, <gdal-dev-request at lists.osgeo.org> wrote:
> Send gdal-dev mailing list submissions to
>         gdal-dev at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/gdal-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         gdal-dev-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of gdal-dev digest..."
> Today's Topics:
>    1. Re: Problem installing gdal from source - dxf-related?
>       (Andreas Neumann)
>    2. Gdal 1.9 and ERDAS Read-Write SDK write projection (netcadturgay)
>    3. Re: Gdal 1.9 and ERDAS Read-Write SDK write projection
>       (Even Rouault)
>    4. Re: Gdal 1.9 and ERDAS Read-Write SDK write projection
>       (netcadturgay)
>    5. conflict bet gdal tiff lib and libgeotiff lib (Pravin Ramteke)
>    6. Re: conflict bet gdal tiff lib and libgeotiff lib (Even Rouault)
> Message: 1
> Date: Tue, 02 Oct 2012 10:41:54 +0200
> From: Andreas Neumann <a.neumann at carto.net>
> To: Even Rouault <even.rouault at mines-paris.org>
> Cc: gdal-dev <gdal-dev at lists.osgeo.org>
> Subject: Re: [gdal-dev] Problem installing gdal from source -
>         dxf-related?
> Message-ID: <da8de41275a79d26ce1743c58fe060f3 at carto.net>
> Content-Type: text/plain; charset=UTF-8; format=flowed
>  Hi Even and others,
>  I did a new checkout and installation works fine now.
>  I also tested the recent dxf writer improvements and can gladly report
>  that filled polygon export now seems to work fine. It also works for
>  holes. Multipolygon features seem to exported as separate polygons. But
>  that is fine for me and perhaps also a limitation of dxf.
>  Thank you for all who worked on fixing the dxf export issues!
>  Andreas
>  On Mon, 01 Oct 2012 16:33:31 +0200, Even Rouault wrote:
> > Andreas,
> > I suspect that your source files don't match the "official" ones. The
> > line
> > numbers don't point to the line numbers of the SVN version. There
> > must have been
> > an error in the process when you updated your source files.
> > Even
>  Andreas Neumann
>  B?schacherstrasse 10A
>  8624 Gr?t (Gossau ZH)
>  Switzerland
> Message: 2
> Date: Tue, 2 Oct 2012 04:39:22 -0700 (PDT)
> From: netcadturgay <turgay.osna at netcad.com.tr>
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] Gdal 1.9 and ERDAS Read-Write SDK write projection
> Message-ID: <1349177962788-5005832.post at n6.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> I open an ECW file in Update mode. Then I set to the projection
> information(with SetProjection method) but ecw file does not change. How
> can
> I solve this problem?
> http://osgeo-org.1560.n6.nabble.com/Gdal-1-9-and-ERDAS-Read-Write-SDK-write-projection-tp5005832.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> Message: 3
> Date: Tue, 02 Oct 2012 14:07:38 +0200
> From: Even Rouault <even.rouault at mines-paris.org>
> To: netcadturgay <turgay.osna at netcad.com.tr>
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Gdal 1.9 and ERDAS Read-Write SDK write
>         projection
> Message-ID: <1349179658.506ad90a8e75e at imp.free.fr>
> Content-Type: text/plain; charset=ISO-8859-1
> Selon netcadturgay <turgay.osna at netcad.com.tr>:
> can
> Did you close properly the dataset ? The ECW header is only rewritten with
> the
> updated information at dataset closing.
> Message: 4
> Date: Tue, 2 Oct 2012 05:37:09 -0700 (PDT)
>         projection
> Message-ID: <1349181429367-5005850.post at n6.nabble.com>
> Yes, I close the dataset properly and now I found problem source. If I try
> to
> set the "Geodesic WGS84", it updates successfully. But if I try to set the
> custom projection, it does not update?
> *Custom WKT*
> PROJCS["(UTM)Universal Transvers Merkator 6?",GEOGCS["EUROPEAN
> 1950",DATUM["European_Datum_1950",SPHEROID["International",6378388.0,297.0],TOWGS84[-87.0,-98.0,-121.0,0.0,0.0,0.0,0.0]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.01745329],AUTHORITY["EPSG","4230"]],PROJECTION["TRANSVERSE_MERCATOR"],PARAMETER["SCALE_FACTOR",0.9996],PARAMETER["CENTRAL_MERIDIAN",33.0],PARAMETER["LATITUDE_OF_ORIGIN",0.0],PARAMETER["FALSE_EASTING",500000.0],PARAMETER["FALSE_NORTHING",0.0],UNIT["meter",1.0]]
> http://osgeo-org.1560.n6.nabble.com/How-to-write-projection-for-ecw-files-in-Gdal-1-9-including-ERDAS-Read-Write-SDK-tp5005832p5005850.html
> Message: 5
> Date: Tue, 2 Oct 2012 22:54:53 +0530
> From: Pravin Ramteke <ramteke0001 at gmail.com>
> Subject: [gdal-dev] conflict bet gdal tiff lib and libgeotiff lib
> Message-ID:
> CAOHb4C9Vvjj0COfazxX-pLmgmKnmxqnqtXtkFdkon5sBbUWuXA at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Respected Sir,
> I m Pravin Ramteke Mtech student from Walchand College Of Engg. Sangli
> Maharashtra, working on Object Tracking in satellite images, fro this i m
> using Orfeo toolbax,
> When operating on .tif image i get an error of
> 0x09edecf0 ***
>  and afer using gdasl in --with-hide-internel=symbols
> i get segmentation fault
> can u please suggest a solution...........
> Thank You,
> Regards
> Pravin B. Ramteke
> MTech-II (CSE)
> Sangli,
> Maharashtra. 416415
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121002/989cc96c/attachment-0001.html
> Message: 6
> Date: Tue, 2 Oct 2012 20:46:39 +0200
> Cc: Pravin Ramteke <ramteke0001 at gmail.com>
> Subject: Re: [gdal-dev] conflict bet gdal tiff lib and libgeotiff lib
> Message-ID: <201210022046.39830.even.rouault at mines-paris.org>
> Content-Type: Text/Plain;  charset="utf-8"
> Le mardi 02 octobre 2012 19:24:53, Pravin Ramteke a ?crit :
> > Respected Sir,
> > 0x09edecf0 ***
> Also try the --with-rename-internal-libtiff-symbols and
> libgeotiff-symbols configure option that have been added in GDAL 1.9
> End of gdal-dev Digest, Vol 101, Issue 3
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121003/febedda4/attachment.html>
