[gdal-dev] How to add alpha channel to tiff image - C++ code
mighty_duck msiljegovic at gmail.com
Wed Oct 3 13:11:43 PDT 2012
Hi Even,
thanks for your quick reply and explanation. I would kindly ask you for more
help, since I'm just trying to adapt this code quickly while still learning
all those concepts...
If I understood you well, those are changes:
hDstDS = GDALCreate(driver, output.c_str(), resX, resY,
                        4, GDALGetRasterDataType(GDALGetRasterBand(hSrcDS,
1)),
                        compressOption);
for (int i = 0; i < GDALGetRasterCount(hSrcDS); ++i)
        GDALRasterBandH hSrcBand = GDALGetRasterBand(hSrcDS, i + 1);
        GDALRasterBandH hDstBand = GDALGetRasterBand(hDstDS, i + 1);
        GDALColorTableH cTable = GDALGetRasterColorTable(hSrcBand);
                GDALSetRasterColorInterpretation(hDstBand,
GDALGetRasterColorInterpretation(hSrcBand));
        if (cTable)
            GDALSetRasterColorTable(hDstBand, cTable);
        //remove code below????
        int success;
        double noData = GDALGetRasterNoDataValue(hSrcBand, &success);
        if (success)
            GDALSetRasterNoDataValue(hDstBand, noData);
        else if (zeroAsTransparent)
            GDALSetRasterNoDataValue(hDstBand, 0);
//edit only alpha channel here...if so what do you mean by that, what
methods to use??
Thanks for understanding.
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-add-alpha-channel-to-tiff-image-C-code-tp5006218p5006225.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
