[gdal-dev] [go-nuts] GDAL Bindings for Go
Luke Roth roth.luke at gmail.com
Thu Oct 4 06:50:49 PDT 2012
Thanks, I just noticed that when I pulled the code to a new machine.
I've renamed the repository to
https://github.com/lukeroth/gdal_go to avoid the problem.
Luke
On Thu, Oct 4, 2012 at 12:57 AM, minux <minux.ma at gmail.com> wrote:
> On Oct 4, 2012 2:46 AM, "Luke Roth" <roth.luke at gmail.com> wrote:
>> set of GDAL bindings for the Go language at
>> https://github.com/lukeroth/gdal.go .
> i suggest you change the project name to avoid ".go" suffix,
> or it  will confuse "go get".
