[gdal-dev] errror in building qgis
SIVA RAMA KRISHNA s.r.kriishna at gmail.com
Fri Oct 5 04:37:31 PDT 2012
Hello all,
            I am trying to build qgis for Qt in fedora
           I have  INSTALLED dependies for  Python pyqt. and sip
          It is building upto following Steps
Scanning dependencies of target python_module_qgis_networkanalysis
[ 92%] Building CXX object
python/CMakeFiles/python_module_qgis_networkanalysis.dir/analysis/network/sipnetworkanalysispart0.cpp.o
python/CMakeFiles/python_module_qgis_networkanalysis.dir/analysis/network/sipnetworkanalysispart1.cpp.o
python/CMakeFiles/python_module_qgis_networkanalysis.dir/analysis/network/sipnetworkanalysispart2.cpp.o
python/CMakeFiles/python_module_qgis_networkanalysis.dir/analysis/network/sipnetworkanalysispart3.cpp.o
Linking CXX shared library ../output/python/qgis/networkanalysis.so
[ 92%] Built target python_module_qgis_networkanalysis
[ 92%] Generating ui_qgsplugininstallerbase.py
      Any Help for the above Problem is greatly apprieciated
  Thanking You
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121005/d1db25aa/attachment.html>
