[gdal-dev] Small meshing utility
Chris Barker chris.barker at noaa.gov
Fri Oct 5 09:11:39 PDT 2012
On Thu, Oct 4, 2012 at 6:31 PM, Tim Keitt <tkeitt at gmail.com> wrote:
> Just letting folks know that we've released an OGR wrapper for the
> Triangle library. It would be great if folks could test it. I could
> also use some help improving the OGR bits.
cool! though I"m a little confused as to how this fits with OGR.
Also -- how did you deal with the fact that triangle calls the system
exit() function on error -- that could bring down whatever your host
process is.
We've written a wrapper around triangle for Python (anyone feel free
to send me a note if you're interested), and we ended up handling that
by spawning another process to run triangle in -- but that has
performance issues (copying data around) which would be nice to avoid.
If only triangle has a nicer licensing scheme -- it really is a nice utility.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
Chris.Barker at noaa.gov
