[gdal-dev] convert dwg/dgn to raster/vector files (windows)
Miro Karpis miroslav.karpis at gmail.com
Fri Oct 5 09:36:40 PDT 2012
thanks, yes that makes sence ;-)
so basically with the dwg library I should be able to make the conversion
using gdal, correct? As far as I know the library is available only to
the open design alliance members (paid membership) correct?
Regarding the dgn format, it should be able to read it and convert it to
for example svg/png format. Am I right?
Once again, thanks for the help.
Regards,
Miro
On Saturday, January 10, 1970, Even Rouault <even.rouault at mines-paris.org>
wrote:
> Selon Miro Karpis <miroslav.karpis at gmail.com>:
>> Hi,
>> please can you help me with following? I'm trying to find the best way to
>> convert dgn/dwg files to vector(svg) and raster(png) formats. In the OGR
>> Vector formats table <http://www.gdal.org/ogr/ogr_formats.html> is stated
>> that dwg and dgn formats are compiled by default.
> No, have a look again ;-)
> Format Name             Code    Compiled by default
> AutoCAD DWG             DWG     No
> Microstation DGN        DGN     Yes
>> On another side I
>> see in AutoCad
>> dwg description <http://www.gdal.org/ogr/drv_dwg.html> that we need Open
>> Design Alliance Teiga library. Does this mean that the Teiga library is
>> included in gdal (it just needs to be included during the build)?
> Not having experimenting that driver myself, but presumably, you need the
Open
> Design Alliance Teiga library when compiling GDAL and at runtime too.
>> Thank you in advance.
>> Regards,
>> Miro
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121005/f3550656/attachment.html>
