[gdal-dev] update to overview resampling methods?
Fri Oct 5 13:55:34 PDT 2012
On Fri, Oct 5, 2012 at 12:56 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> > >> 3) why is AVERAGE_MP considered unfit for use in the gdaladdo docs?
> > >> and why is it still available?
> > > Historical remain ? Could likely be undocumented.
> > ok I will remove it, should it be removed/commented from the code also?
> Undocumenting seems appropriate. As far as removing the implementation, you
> might want to check with the original committer (FrankW)
Etienne,
Are AVERAGE_MP and AVERAGE_MAGPHASE really different things?  That seems
odd.
I don't know why it reports them as not ready for production use.  I would
not want them removed, but I don't mind them not being documented.
I peeked at the qgis bug report about magphase but I see the test data is
no longer available.  If there are problems with magphase support that can
be demonstrated and filed as a bug I'd be interested in resolving them.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121005/54549c26/attachment-0001.html>
