[gdal-dev] Small meshing utility
Tim Keitt tkeitt at gmail.com
Sun Oct 7 20:33:01 PDT 2012
On Fri, Oct 5, 2012 at 11:11 AM, Chris Barker <chris.barker at noaa.gov> wrote:
> On Thu, Oct 4, 2012 at 6:31 PM, Tim Keitt <tkeitt at gmail.com> wrote:
>> Just letting folks know that we've released an OGR wrapper for the
>> Triangle library. It would be great if folks could test it. I could
>> also use some help improving the OGR bits.
> cool! though I"m a little confused as to how this fits with OGR.
OGR is used for i/o.
> Also -- how did you deal with the fact that triangle calls the system
> exit() function on error -- that could bring down whatever your host
> process is.
Its a simple command line utility. Not much harm done if it calls exit.
> We've written a wrapper around triangle for Python (anyone feel free
> to send me a note if you're interested), and we ended up handling that
> by spawning another process to run triangle in -- but that has
> performance issues (copying data around) which would be nice to avoid.
I don't call triangle, I pass arguments to the C-level API.
> If only triangle has a nicer licensing scheme -- it really is a nice utility.
Only prohibition is you can't sell it without a license.
THK
> -Chris
> Christopher Barker, Ph.D.
> Oceanographer
> Emergency Response Division
> NOAA/NOS/OR&R            (206) 526-6959   voice
> 7600 Sand Point Way NE   (206) 526-6329   fax
> Seattle, WA  98115       (206) 526-6317   main reception
> Chris.Barker at noaa.gov
Timothy H. Keitt
http://www.keittlab.org/
