[gdal-dev] Topological pointer
Nikhil Sai Parupalli nikhil.parupalli at iictechnologies.com
Sun Oct 7 23:15:02 PDT 2012
Frank,
Thanks for the reply in below data
  NAME_RCNM (IntegerList) = (7:130,130,130,130,130,130,130)
   NAME_RCID (IntegerList) = (7:691,391,690,52,1336,1503,1512)
   ORNT (IntegerList) = (7:2,2,2,2,1,1,1)
   USAG (IntegerList) = (7:1,1,1,1,1,1,1)
   MASK (IntegerList) = (7:255,255,255,255,255,255,255)
 RCID 691 ORNT has  2 and USAG is 1 based on this data we could identify that RCID 691 is of exterior boundary with reverse direction.
So if I have 1000 RCID in  NAME_RCID which is vise versa for the above condition I need to display that RCIDS list as errors.
So it makes 1000 conditional checks hence reducing performance.
Please let us know further.
Thanks and Regards
Note: Do not print this email until and unless it is really required. Save paper , stay Green
________________________________________
Sent: Monday, October 08, 2012 11:42 AM
To: Frank Warmerdam; Nikhil Sai Parupalli
Cc: gdal-dev at lists.osgeo.org
Subject: RE: [gdal-dev] Topological pointer
Frank,
Please let us know further..
Thanks & Regards
Srikanth Rao Sidduri,
From: gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org] on behalf of Frank Warmerdam [warmerdam at pobox.com]
Sent: Monday, October 08, 2012 10:49 AM
To: Nikhil Sai Parupalli
Subject: Re: [gdal-dev] Topological pointer
On 12-10-07 10:02 PM, Nikhil Sai Parupalli wrote:
> Frank,
> As said I have my system variable as
> "RETURN_PRIMITIVES=ON,RETURN_LINKAGES=ON,LNAM_REFS=ON,
> UPDATES=APPLY,SPLIT_MULTIPOINT=ON,ADD_SOUNDG_DEPTH=ON"
> but still I couldn't  see TOPI field retrieved in my dataset..
> Will you elaborate and let me know.
Nikhil,
I don't know why you don't see it.  I see it fine on the "Edge"
layer which contains the linestring vector objects.
eg.
  OGRFeature(Edge):18
   RCNM (Integer) = 130
   RCID (Integer) = 19
   RVER (Integer) = 1
   RUIN (Integer) = 1
   NAME_RCNM_0 (Integer) = 120
   NAME_RCID_0 (Integer) = 21
   ORNT_0 (Integer) = 255
   USAG_0 (Integer) = 255
   TOPI_0 (Integer) = 1
   MASK_0 (Integer) = 255
   NAME_RCNM_1 (Integer) = 120
   NAME_RCID_1 (Integer) = 20
   ORNT_1 (Integer) = 255
   USAG_1 (Integer) = 255
   TOPI_1 (Integer) = 2
   MASK_1 (Integer) = 255
   LINESTRING (60.775 -32.6249972)
> I have one more question:
> How do we find  area outer boundaries are encoded clockwise based
> on Orientation or USAG.
> here when I retrieve S57 dataset I get multiple ORNT values for a single object.
I am not aware of any definition of outer ring winding direction.
I think the ORNT field values you see on polygons are indicating
which direction the edges were used in when composing the ring(s)
of the polygon.
So in the above feature, RCID 691 is used with orientation "2",
usage "1" and mask "255".
Best regards,
light and sound - activate the windows | http://home.gdal.org/warmerda
and watch the world go round - Rush    | Geospatial Software Developer
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
