[gdal-dev] OGR SQL: Excecuting select where column name contains "."
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Mon Oct 8 02:00:14 PDT 2012
Odd Ragnar Lydersen <Odd-Ragnar.Lydersen <at> powel.no> writes:
> I see you have been busy discussing how to handle column names which contain
dot "."
> My problem is that I can't get any reasonable values from the query I make,
whether I use "str1.str2" or
> 'str1.str2' in my expression.
> Please help, or confirm if I'm trying to do something illegal
I can confirm that it is not illegal per se because the following works. I hope
that the backslashes and everything go through properly.
ogrinfo WFS:http://188.64.1.61/cgi-bin/tinyows
 -sql "select \"nom.dept\" from \"tows:dot.test\""
It is an open WFS server and you can test it with ogrinfo and from your code
too. However, I will remove the dot.test feature type sooner or later. Verify
and make your code to work in a similar way than ogrinfo.
-Jukka-
