[gdal-dev] clipping multiple shapefiles from a set of clipping polygons
maning sambale emmanuel.sambale at gmail.com
Mon Oct 8 04:13:29 PDT 2012
HI,
I have a shapefile polygon that contains administrative boundaries and
a several shapefile of various features.  I want to create separate
shapefiles of each layer feature for each administrative boundaries in
the clipping layer.
For example,
AdminPoly1
 - AdminPoly1_point.shp
 - AdminPoly1_line.shp
 - AdminPoly1_poly.shp
AdminPoly2
and so on.
Any advice?
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
