[gdal-dev] clipping multiple shapefiles from a set of clipping polygons
maning sambale emmanuel.sambale at gmail.com
Mon Oct 8 05:21:13 PDT 2012
Thanks! Is this implemented already in the stable build?
Maning Sambale (mobile)
On Oct 8, 2012 7:28 PM, "Ari Jolma" <ari.jolma at gmail.com> wrote:
> On 10/08/2012 02:13 PM, maning sambale wrote:
>> HI,
>> I have a shapefile polygon that contains administrative boundaries and
>> a several shapefile of various features.  I want to create separate
>> shapefiles of each layer feature for each administrative boundaries in
>> the clipping layer.
>> For example,
>> AdminPoly1
>>   - AdminPoly1_point.shp
>>   - AdminPoly1_line.shp
>>   - AdminPoly1_poly.shp
>> AdminPoly2
>> and so on.
>> Any advice?
> Maning,
> The new layer methods may be what you're looking for:
> http://trac.osgeo.org/gdal/**wiki/LayerAlgebra<http://trac.osgeo.org/gdal/wiki/LayerAlgebra>
> Ari
> ______________________________**_________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121008/8f2da059/attachment.html>
