[gdal-dev] clipping multiple shapefiles from a set of clipping polygons
maning sambale emmanuel.sambale at gmail.com
Tue Oct 9 03:41:32 PDT 2012
I see, is there a scripting workaround using 1.9?
On Mon, Oct 8, 2012 at 9:14 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> generally speaking new features do not go into current stable version
> (1.9), they will be incorporated into next stable version (probably
> 2.0).
> Etienne
> On Mon, Oct 8, 2012 at 9:57 AM, Ari Jolma <ari.jolma at gmail.com> wrote:
>> On 10/08/2012 03:21 PM, maning sambale wrote:
>> Thanks! Is this implemented already in the stable build?
>> It's currently only in the trunk version.
>> Ari
>> Maning Sambale (mobile)
>> On Oct 8, 2012 7:28 PM, "Ari Jolma" <ari.jolma at gmail.com> wrote:
>>> On 10/08/2012 02:13 PM, maning sambale wrote:
>>>> HI,
>>>> I have a shapefile polygon that contains administrative boundaries and
>>>> a several shapefile of various features.  I want to create separate
>>>> shapefiles of each layer feature for each administrative boundaries in
>>>> the clipping layer.
>>>> For example,
>>>> AdminPoly1
>>>>   - AdminPoly1_point.shp
>>>>   - AdminPoly1_line.shp
>>>>   - AdminPoly1_poly.shp
>>>> AdminPoly2
>>>> and so on.
>>>> Any advice?
>>> Maning,
>>> The new layer methods may be what you're looking for:
>>> http://trac.osgeo.org/gdal/wiki/LayerAlgebra
>>> Ari
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
