[gdal-dev] Small meshing utility
Chris Barker chris.barker at noaa.gov
Tue Oct 9 09:07:34 PDT 2012
On Sun, Oct 7, 2012 at 8:33 PM, Tim Keitt <tkeitt at gmail.com> wrote:
>> cool! though I"m a little confused as to how this fits with OGR.
> OGR is used for i/o.
I see -- so you've written something like the triangle command line
utility, but with OGR for IO, so you don't need to use triangles
particular data file format? sounds useful.
>> Also -- how did you deal with the fact that triangle calls the system
>> exit() function on error -- that could bring down whatever your host
>> process is.
> Its a simple command line utility. Not much harm done if it calls exit.
I see -- I was thinking you'd extended the OGR library, rather than
the OGR command line tools. I get it now.
>> We've written a wrapper around triangle for Python (anyone feel free
>> to send me a note if you're interested), and we ended up handling that
>> by spawning another process to run triangle in -- but that has
>> performance issues (copying data around) which would be nice to avoid.
> I don't call triangle, I pass arguments to the C-level API.
neither do we -- we also use the C-API -- but if you need to run it in
another process you need to ass the data around somehow -- and if you
want to call it as a library from a longer-running application, then
the calls to exit() will kill you (well, kill your app...) if you
don't run it in another process.
>> If only triangle has a nicer licensing scheme -- it really is a nice utility.
> Only prohibition is you can't sell it without a license.
well, "commercial" is not clearly defined in the license -- why not
just GPL the darn thing!
and it's not BSD-compatible in any case.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
Chris.Barker at noaa.gov
