[gdal-dev] [update] Re: Travis CI continuous integration service for GDAL
Angelos Tzotsos gcpp.kalxas at gmail.com
Wed Oct 10 01:34:12 PDT 2012
On 10/10/2012 02:16 AM, Even Rouault wrote:
> Le dimanche 07 octobre 2012 11:42:30, Even Rouault a écrit :
>> Hi,
>> Following a recent similar move from MapServer, I've setup an instance of
>> Travis CI, hosted continuous integration service. After each SVN commit in
>> trunk, GDAL is built and the Java, Perl and Python tests are run.
>> Travis CI currently offers Ubuntu 12.04 i386 virtual machines. The GDAL
>> build is configured with almost any possible dependencies to external
>> libraries (see http://trac.osgeo.org/gdal/wiki/Buildbot for the list)
>> You can access to the latest builds here :
>> https://travis-ci.org/#!/rouault/gdal/builds
> Just a follow-up to inform you that GDAL SVN is now fully mirrored (meaning
> that it includes all branches and tags) at :
> https://github.com/OSGeo/gdal
> (The update script still runs on my PC.)
> Travis builds are available consequently at :
> https://travis-ci.org/#!/OSGeo/gdal
> Both trunk and 1.9 branch benefit from Travis configuration.
> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Hi all,
This is great news.
I believe that gdal would benefit a lot with a full move to git.
Also I am wondering if we should add more OSGeo projects and members
under this OSGeo github account.
What do you think?
Regards,
Angelos
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
