[gdal-dev] S57 dataset boundary issue
Nikhil Sai Parupalli nikhil.parupalli at iictechnologies.com
Wed Oct 10 22:26:47 PDT 2012
Hey Sylvain,
Thanks for your inputs, we have successfully implemented the same in our project .
I have one more question i.e
If I have a polygon how to find out edges of it programmatic do we have any function to get all  the edges of polygon(area)
Thanks and Regards
Note: Do not print this email until and unless it is really required. Save paper , stay Green
________________________________________
Sent: Wednesday, October 10, 2012 9:07 PM
To: s duclos
Subject: RE: [gdal-dev] S57 dataset boundary issue
Thanks and Regards
Sent: Wednesday, October 10, 2012 8:43 PM
To: Nikhil Sai Parupalli; Frank Warmerdam
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] S57 dataset boundary issue
Hi Nikhil,
> Based on the code which you have sent we could find out CW and CCW, but not
> outer/inner
The outer ring of OGRGeometryH poly is  the ring 0 (zero).
In C code the OGR call:
            guint        nRingCount = OGR_G_GetGeometryCount(hGeom);
will give you the number of rings in a poly.
Say there is 2 rings for this hGeom. Then the outer ring is
    OGRGeometryH *hGeomRef_outter  = OGR_G_GetGeometryRef(hGeom, 0);
and the inner ring is
    OGRGeometryH *hGeomRef_inner  = OGR_G_GetGeometryRef(hGeom, 1);
> Please have a look at that data set once and let me know.
There is nothing in attachment
rgds,
Sylvain.
----- Original Message -----
> From: Nikhil Sai Parupalli <nikhil.parupalli at iictechnologies.com>
> To: s duclos <sylvain_duclos at yahoo.com>; Frank Warmerdam <warmerdam at pobox.com>
> Cc: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> Sent: Wednesday, October 10, 2012 10:40:27 AM
> Hey Sylvain,
> Thanks for trying the data which I have sent.
> Could you be helping me how this works like outer boundary and inner boundary.
> outer/inner
> Or if you have any sample data with simple representation of outer and inner
> boundaries please do share with me.
> Thanks and Regards
> , stay Green
> From: s duclos [sylvain_duclos at yahoo.com]
> Sent: Wednesday, October 10, 2012 7:59 PM
> Hi Nikhil,
> I loaded US1GC09M//US1GC09M.000 .. it's huge :)
> It's the Gulf of Mexico .. now where should I look ?
> About the inner / outer ring. As I said before, I just assume that OGR
> send me the outer ring first. And, up to now, my code is working fine.
> rgds,
> Sylvain.
>>  Sent: Wednesday, October 10, 2012 9:40:54 AM
>>  Could you try on this data set please
>>  Thanks and Regards
> paper
>>  , stay Green
>>  Sent: Wednesday, October 10, 2012 7:02 PM
>>  Nikhil,
>>  I loaded your ENC.
>>  I see a number of depth area (DEPARE) and anchor zone area (ACHARE).
>>  But no inner ring!
>>  Is there an inner rings somewhere I should see?
>>  rgds,
>>  Sylvain.
>>>   Sent: Wednesday, October 10, 2012 8:00:41 AM
>>>   Duclos,
>>>   Please see this sample data attached.
>>>   So as per the code given by you we have tried and got result i.e able
> to
>>  find
>>>   out area
>>>   some times it shows area<0 and some times area>0 hence we get
> CW and
>>  CCW.
>>>   But how do we classify in layer which is outer boundary and which is
> inner
>>>   boundary
>>>   Geometry testgeo = geomLAKARE.GetBoundary();
>>>                                       double area = 0;
>>>                                       for (int l = 0; l <
>>>   testgeo.GetPointCount() - 1; l++)
>>>                                           double x1 = testgeo.GetX(l);
>>>                                           double y1 = testgeo.GetY(l);
>>>                                           double x2 = testgeo.GetX(l +
> 1);
>>>                                           double y2 = testgeo.GetY(l +
> 1);
>>>                                           area += (x1 * y2) - (x2 * y1);
>>>   Thanks and Regards
> Save
>>  paper
>>>   , stay Green
>>>   Sent: Tuesday, October 09, 2012 11:58 PM
>>>   To: Frank Warmerdam; Nikhil Sai Parupalli
>>>   Frank & Nikhil,
>>>   Frank asked:
>>>>   are, I'm not sure what I or others can do about
>>>>   the performance cost of checking.
>>>   If I understand the problem, then it cost nothing!
>>>   You have to check the winding while loading a OGRGeometryH
>>>   like so:
>>>                   double area = 0;
>>>                   for (unsigned int i=0; i<vert_count-1; i++) {
>>>                       double x1 = OGR_G_GetX(hRing, i);
>>>                       double y1 = OGR_G_GetY(hRing, i);
>>>                       double x2 = OGR_G_GetX(hRing, i+1);
>>>                       double y2 = OGR_G_GetY(hRing, i+1);
>>>                       area += (x1*y2) - (x2*y1);
>>>   If the area < 0 then it is CW (clockwise) and > 0 is CCW
> (Counter
>>  CW).
>>>   Note that in S57 the exterior ring must be CW and
>>>   interior ring are CCW.
>>>   But in S57 there is no order between rings. So interior ring
>>>   might come first. I think WKT fix this. In my code I assume
>>>   that OGR place the exterior ring first.
>>>   We have been trough this before. At the time the question
>>>   was if S57 allow for many exterior ring for the same poly.
>>>   I guess it all depend on HO and how they encode the data.
>>>   I'm using mostly Canadian ENC and found no problem.
>>>   But other HO might encode ENC differently ..
>>>   rdgs,
>>>   Sylvain Duclos.
>>>>    From: Frank Warmerdam <warmerdam at pobox.com>
>>>>   Sent: Tuesday, October 9, 2012 12:25:29 PM
>>>>   On Mon, Oct 8, 2012 at 10:28 PM, Nikhil Sai Parupalli
>>>   <nikhil.parupalli at iictechnologies.com> wrote:
>>>>   HI All,
>>>>>   Thanks for the reply in below data
>>>>>     NAME_RCNM (IntegerList) = (7:130,130,130,130,130,130,130)
>>>>>      NAME_RCID (IntegerList) = (7:691,391,690,52,1336,1503,1512)
>>>>>      ORNT (IntegerList) = (7:2,2,2,2,1,1,1)
>>>>>      USAG (IntegerList) = (7:1,1,1,1,1,1,1)
>>>>>      MASK (IntegerList) = (7:255,255,255,255,255,255,255)
>>>>>    RCID 691 ORNT has  2 and USAG is 1 based on this data we
> could
>>  identify
>>>   that RCID 691 is of exterior boundary with reverse direction.
>>>>>   So if I have 1000 RCID in  NAME_RCID which is vise versa for
> the
>>  above
>>>   condition I need to display that RCIDS list as errors.
>>>>>   So it makes 1000 conditional checks hence reducing
> performance.
>>>>>   Please let us know further.
>>>>   Nikhil,
>>>>   I'm afraid I don't follow your point.  Are you trying to
>>>>   do some sort of ring orientation validation and identify
>>>>   ones that don't match your expectations?  And you
>>>>   are concerned about the performance cost?
>>>>   I don't know why you are doing this, and if you
>>>>   Best regards,--
>>>>   I set the clouds in motion - turn up   | Frank Warmerdam,
>>>>   light and sound - activate the windows |
> http://pobox.com/~warmerdam
>>>>   and watch the world go round - Rush    | Geospatial Software
> Developer
>>>>   _______________________________________________
>>>>   gdal-dev mailing list
>>>>   http://lists.osgeo.org/mailman/listinfo/gdal-dev
