[gdal-dev] Data Set Parameter [DSPM]
Nikhil Sai Parupalli nikhil.parupalli at iictechnologies.com
Sun Oct 14 23:16:43 PDT 2012
Can any one help me out how to get Data Set Parameter  [DSPM] field for S57 dataset  into application using GDAL.
I need to check below things for my application
Check that HDAT = 2 [WGS 84].
Check that DUNI = 1 [metres].
Check that PUNI = 1 [metres].
Check that COUN = 1 [latitude/longitude].
Thanks and Regards
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121015/216902bc/attachment.html>
