[gdal-dev] Setting DataType in ReadAsArray
    Antonio Falciano
    afalciano at yahoo.it
    Tue Oct 16 13:59:45 PDT 2012
Il 16/10/2012 22.05, elliott at cpi.com ha scritto:
> Hello,
> Does anybody know of a way to set the data type in the call ReadAsArray.
> It is currently reading a field as an unsigned int and it needs to be read
> as a signed int.
ReadAsArray returns substantially a numpy array, so you can use np
functions and methods of conversions between data types [1]. Finally,
the simplest way consists into using the .astype() method. Hope this helps!
Cheers,
Antonio
[1] http://docs.scipy.org/doc/numpy/user/basics.types.html
Antonio Falciano
http://www.linkedin.com/in/antoniofalciano
