[gdal-dev] Using gdal_rasterize to mask ENVI file Using ESRI SHP format Vector
Peter Willis pwillis at aslenv.com
Wed Oct 17 14:59:05 PDT 2012
Hello,
Is it possible to use ESRI SHP polygon file to mask
ENVI  BSQ img format files with more than 1 band?
I can mask a GTiff file using the SHP but ENVI file does not
appear to work.  Gdal version is  1.6.3 .
The documentation appears unclear for any raster that is not
specifically GTiff.
Thanks,
Peter
