[gdal-dev] Problem using image bands
jcurru jcurru at yahoo.es
Fri Oct 19 06:45:55 PDT 2012
Ouch!
Thank you very much, Even. I should have asked sooner, instead of going to
bed at 5 in the morning... :-)
Yes, I have to read into a RGB buffer, but your solution would increase a
lot the loading time for other images that are working well.
I have read this: http://trac.osgeo.org/gdal/changeset/25107. So, do you
recommend me to change the code in ecwdataset.cpp and rebuild the library?
Thanks again!
View this message in context: http://osgeo-org.1560.n6.nabble.com/Problem-using-image-bands-tp5009873p5009877.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
