[gdal-dev] How to use gdal_polygonize.py
Paul Meems bontepaarden at gmail.com
Mon Oct 22 03:38:11 PDT 2012
Hi all,
I'm investigating gdal_polygonize.py
I'm thinking of using it to convert a DEM-file to a polygon shapefile.
I did a quick test using gdal_polygonize.py logan.tif -f "ESRI Shapefile"
logan_poly.shp and got a shapefile.
But this shapefile is huge, it created a polygon for every pixel value.
I was thinking it would be a bit more like gdal_contour which uses an
interval.
Am I not understanding the purpose of gdal_polygonize?
Can somebody tell me some real-life use cases when to use this?
Thanks,
Paul
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121022/64361364/attachment.html>
