[gdal-dev] How to use gdal_polygonize.py
Ves Nikos vesnikos at gmail.com
Tue Oct 23 02:55:24 PDT 2012
Hey Paul,
I think  [ gdal_contour ]  is more close to what you think you need:
here's a quick turorial I just found on it:
http://woostuff.wordpress.com/2011/09/27/generating-contours-using-gdal-via-shell-or-qgis/
Kind regards,
Ves Nikos
Στις 22/10/2012 1:38 μμ, ο/η Paul Meems έγραψε:
> Hi all,
> I'm investigating gdal_polygonize.py
> I'm thinking of using it to convert a DEM-file to a polygon shapefile.
> I did a quick test using gdal_polygonize.py logan.tif -f "ESRI
> Shapefile" logan_poly.shp and got a shapefile.
> But this shapefile is huge, it created a polygon for every pixel value.
> I was thinking it would be a bit more like gdal_contour which uses an
> interval.
> Am I not understanding the purpose of gdal_polygonize?
> Can somebody tell me some real-life use cases when to use this?
> Thanks,
> Paul
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
