[gdal-dev] Having problems reading a GRIB2 file with GDAL driver
Rick Wayne
fewayne at wisc.edu
Wed Oct 24 10:21:08 PDT 2012
Dear Jeff,
I want to import it -- probably tiled and pyramid-ed -- into a PostGIS
2.0 raster, to be published with GeoServer. I can use wgrib2 to create
a CSV file without trouble, so one option would be to use gdal_grid to
re-create the raster in, say, a GeoTIFF from the CSV. That seems
rather clunky, and I'm a little concerned about re-interpolating
already interpolated data. But if the files won't go into the PostGIS
raster import utility as is, they won't go in.
Roger, I will try hacking the four trailing bytes off the file and see
whether the result is usable.
Thanks to you both!
rw
On Oct 23, 2012, at 3:35 PM, Jeff Lake wrote:
> That's a common print out from the GRIB driver
> what are you wanting to do w/ the GRIB file ..
> I might have some better solutions than using GDAL
Roger wrote:
> I had the same problem, but with two trailing bytes. [...]
> I solved the problem by removing the bytes using:
> dd if=gribFileNameWithTrailingBytes
> of=gribFileNameWithoutTrailingBytes bs=1 skip=0 count=219886
> Where count is the original grib file size minus the trailing bytes
> (four, in your case).
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121024/29a493f2/attachment.html>
