[gdal-dev] Question about using crop_to_cutline
António Rocha antonio.rocha at deimos.com.pt
Thu Oct 25 07:52:59 PDT 2012
Hi
Sorry Joaquim but I'm really trying to find a solution based on GDAL.
Thanks
Antonio
> I have a close functionality in Mirone but it was developed mainly for
> grids, though it works also with images. With a grid/image loaded,
> load the polygon too. Next right-click on the polygon line and select
> ROI Crop Tools -> Crop Image (or any of the other related options) and
> it's done. One thing you may not like is that the resulting image is
> not of the same size (extent) as the original. This is so because I
> (don't remember anymore why) decided to save only the extent
> corresponding to the BoundingBox of the polygon. Joaquim
